2" Beader.
A
ajh
Anyone got a beader that can do 2" aluminum pipe? I've made enough alterations to my turbo setup to need to do new intercooler pipes.
A
ajh
No, it's a roller tool to put the end-beads on the pipes that keep them from blowing off under pressure. I had to move my radiator backwards to make enough room for both the new intercooler and the winch mount which now means I need to shorten and re-route the intercooler pipes slightly. Might be able to use get some off-the-shelf joiners and some 51mm silicone hose but I wanted the option of making up custom pipes as well. Buying the proper tool runs from $80 for a really cheap one to about $300 for one that works. :)
