Another guestion... Limited Stip
H
handsomeDave
How is a limited slip differential good? I understand that it's useful when cornering because it allows one wheel to spin faster than the other. But in the example of like a RWD charger, with a limited slip differential, doesn't it give the power to the wheel that has the least traction? how is that helpful? And why is that better than an open differential?
Depends on the differential type.
Any power flow is better than none.
I don't know about the Charger but I do know the Torsen in my S2000. It applies power to the wheel with the most traction. Can lead to some fun spins and such when cresting a hill at 8000+ RPM and hitting a puddle on the track. Not that I'd know anything about that. ;) Btw, Honda F20C engines take a while to re-light after being run backwards.
Also note that less traction does not mean no traction...
