r0k0
I've been having lots of bogging problem with the engine,
2000 Chevrolet Blazer 4.3L Vortec 5 Speed
What i've changed :
Autolite Platinum Spark plugs
NGK Spark wires
Cap / Rotor
MSD Ignition Coil
GM Fuel Filter
Now, i should of went for AC Delco plugs but at 16$ a pieces, 120$ wasn't available.. would NGK Iridium IX be better then the Autolite Platinum ? AC Delco are Platinum plugs
other options are maybe low fuel pressure from pump ( need a fuel pressure gauge if someone has one to...
What i've changed :
NGK Spark wires
Cap / Rotor
MSD Ignition Coil
GM Fuel Filter
