Stan-yj
Currently trying to get the crankshaft set up. New crank, new bearings. Noticed with the the rear main bearing there were clearance issues with the bearing hitting a flange on the rear of the crank shaft. When i compared the new bearing with old one, they are the same size, also the old bearing fits the same way with the old crank. Ill try and get some pictures up soon.
Can't get the crank to rotate with everything torqued to spec. Anyone delt with this problem?
