Built 98 Jeep TJ, hp44/hp60, ARB's, 36" Iroks
This is one of those my loss is your gain kind of things. Highlights include HP60 in the rear, HP44 in the front, ARB air lockers, 36" bias iroks.
1998 Jeep TJ Sahara
4.0L (manual)
163,528 KM
$14 000
I have always aimed to keep this jeep as mostly street legal. Although it has been a dedicated trail truck for me for the last three years...
Impact
Selling axle's separate...
Are the front shafts stock/narrowed? Or aftermarket shafts? Chromo?
Was the axle narrowed just enough to clear out the cast in wedges? Or what was done for that?
Does the rear disc brakes come with park brakes built in? (as per comment i'm guessing no e-brake?)
When buying new brake components what are they specified as?
Are the rear shafts "special" or available off the shelf?
I'm guessing that the rear is semi floating?
Does the rear come with spare shafts?
What is the WMS-WMS?
Does it also come with an air compressr/hardware to run the air lockers?
Have you ever broken any shafts running the 36's?
Are you also looking for stock suspension components?
Stock tires and rims? lp30 (also have lp44)/lp44, 3:73 (less then 45,000 kms on axles/brakes), 30's on 15's (less then 20,000 kms).
Questions answered in red.
The axle was narrowed. They are aftermarket shafts but I do not know if they are chromo. I bought the axle used. The shafts are 30 spline.
Not sure. But the axle is set up correctly, it works fine with ~4" of lift.
Yes, the rear brakes have an e-brake built in. I need a new e-brake cable, that's why it doesn't work currently
I will have to check on the rear, but if memory serves the brakes are the Ford Explorer discs like Tera uses (ebrake setup included). For the front, you just source rotors / pads for a 1979 Ford Bronco.
If a stock tj width 35 spline chromoly axle shaft is considered off the shelf, then yes. If you ever had an issue, all you do is measure the length of the shaft and order up a new one (for either the front or rear) from your favourite axle shaft company.
Yes
No. I only have spares for the front.
Stock WMS-WMS. 60.5"?
I'm sure we could work something out...
Nope. I went with this setup so I wouldn't have issues running 36's.
No
As long as they are already set up for TJ, either would be ok.
I'd prefer to be on larger than 30's, but, if you are interested, we might be able to work something out.
G
Grumpy
Did you change the oil pan dude?? (memories of spring RC...)
Tim :beer:
A little sad about that, having you build it was one of the most fun things I've done in mods for the Jeep.
That's Cool. I am glad it is going to him. He has been bugging me for a while to build him one but the sale of my house fawked all that up. :beer::beer:
It came at the right time... I almost bought a tube notcher about a week ago in anticipation of bending my own with your bender.
Part of me regrets it not to be able to build, but i just have too many other things i need to address as well and i had no idea when i was going to get it done.
