can I make a hydraulic clutch line from brake line parts?
funkysandman
Since I can't find a replacement clutch line anywhere, can I make one from a pre-assembled brake hard line together with a brake flex line?
No reason why not that I can think of. The clutch line will see significantly lower pressures anyway.
Yes you could. Same type fluid, lower working presure, lower temperature.
Make sure the hard line portion is solidly mounted to the vehicle so that it doesn't vibrate/move and fatigue into failure.
funkysandman
ok, I'll give it a go. I can grab a hard brake line off the shelf and bend it up, not sure what flex line I can use, we'll see.
