I went out to my pile of axles figuring I could pull a stub axle out of a CJ7 front axle to fix the PITA hybrid axle on the front of my XJ. I broke the WARN 38248 axle on the XJ's front end.
I pulled the shaft and brought it into the Man Lab in order to separate the U-joint when I noticed that it is the small 260X style U-joint. Shazbot! I need the 297X style CJ7 axle.
Supposedly I can use the stub axle off a Scout II... I'll pull one out of my pile to see if it'll work so I'm not...
