chassis work
G
grove69
He, I am new to all this and I just bought a 94 toyota 4x4 and I need to have some welding work done on the chassis. Two small rust holes. Anyone suggest someone that you trust and does a good job?
thx
G
grove69
yeh I saw all the recalls but I want to restore my truck. I've seen some good restorations andI'd rather do that than give it back to Yota.I've put a fair amount into the truck and am starting to build a relationship with my little ripper....
ToyTaco
Only the recall only applies to Tacomas 95.5 -04. 95.5 -00, if the frames had any holes (punched with an air hammer) it was a total buy out 1.5 times what a third party appraised it at. check tacoma terratory or yota tech for more details. i paid 7500 for a 96 tacoma drove the $hit outta it for 3 years and got a buy out of 12000 last september. then i stripped it in mendes toyotas back yard. rime=s tires cold air fender flairs exhaust header cat and left the oem parts in the box. if it a 94 your stuck with it, clean up the rust ad weld a patch over it. where are the holes? in the typical yota spots between the the cab and box near the spring hanger?
G
grove69
The rust is near the back, around the axle. I will have the frame cleaned up, and have it patched. I came across a garage in Chicago that rebuilds the chassis front to back to a nearly new state for $1600. I may go on a holiday in Chicago this summer.
