CNC plasma or laser cutting in ottawa
BLSXJ
Does anyone in the ottawa area do small CNC plasma/laser cutting?
I'm looking to get a few custom gussets cut as well as a custom plate cut and bent.
material in question will either be 1/8" or 3/16" steel
I found Virtucom, any others?
For what it's worth, he also has a nice lathe and does some machining too. One stop shopping.
I'd contacted Virtucom and also Acufab a few weeks ago for pricing on cutting some stuff too big to fit on Mike's table. Haven't heard back from either of them, I'm not too impressed.
Mike is definetely the guy you want to see.
If you are only looking at bending small parts, you can use a regular shop press, don't need a big fancy press brake. Weld 2 pieces of heavy angle onto a heavier piece of flat plate ^^ and use a 3rd piece of angle V mounted on the bottom of the piston
Impact
BLSXJ talk to Mike! He did my tramp stamp and did an excellent job IMO plus I'm sure he could make you drool over some of his build parts he has laying around...
