Coil overs on a daily driver?
Are coil overs suitable for a vehicle that will see service as a daily driver?
Are coil overs temperature (i.e. -30 deg C) friendly?
Will they tolerate salt spray as well as any normal suspension part?
What's typical turn around on getting a replacement part/component?
BillaVista
PrettyBoy
Are coil overs suitable for a vehicle that will see service as a daily driver??
Certainly. In basic principle / operation they're no different than any other system - a spring and a damper (shock). many sports cars use coil-overs - albeit short ones not like the long travel versions. No reason long travel can't be streetable though. One issue is - they are so easily customizable that there are a lot of ways to get it wrong, and then people blame the tool.
Are coil overs temperature (i.e. -30 deg C) friendly??
Same as any other damper, they will be affected by temperatures. Not particularly any more/less.
Will they tolerate salt spray as well as any normal suspension part???
Depends if you mean as well as or as poorly as any other :flipoff: To keep them looking good will take quite a bit more maintenance than your average cnadian tire painted shock. And there's also the fact that they cost a bunch so when they get ratty you feel bad. Also, you ca';t stop the springs and sliders from rubbing the body - so, no, not the best for a harsh salt-spray environement (although I can attest that they still work fine even when looking ratty)
Polyperformance have great service, good prices, and any part you could need. Turnaround same as any other part ordered from Cali.
