D30 HP or Other
JohnnyCrash
Hi, looking for an HP Dana 30 with 3.73 Gears, or similar.
I have noticed that Mine appears to be bent on the drivers side.
The ABS Ring on the axle is very close to the ball joint where as on the passengers side it is atleast 3/4" away.
This is causing a camber issue on the one side.
Thanks!!
JohnnyCrash
Ive got a lockright in mine, wouldnt mind the gusset, and do you know where i can get a set of 4.88 for my rear d35 to match? How much you want for it?
