I don't think so. There is not enough clearance with the axle shaft in. The ball joint is press fit and I can't see a way to get any type of c clamp style press in with the shaft in. And if you are going as far to take the shaft out you might aswell save the hassle and disassemble the while knuckle. my two cents
