Probably a silly question but should there be a little bit of play in the gears onthe front output shaft? I pressed on the new bearings and I can't get them to go on any tighter.
Want to make sure before I move on.
I am not talking end play, I am talking about a bit of space between the gear and the bearing and shoulder that it can wobble a bit. Both the hi and lo gears do this, I can't see how I could have mucked it up. I can take video if that helps.
