C
CJMunky
Wagoneer 44's
Unknown gear ratio, I do not think they are a matched set. I could open them up if required.
Passenger side front diff
Flat top knuckles, unmolested
Has tie rod and drag link,
Also has drive plates, not hubs
6 on 5.5 bolt pattern
They have ujoint ubolts, not straps and bolts
I have new brake parts for them.
New Discs
New Calipers
New Pads,
and for the rear...
New Shoes
New Spring kit
New wheel cylinders
Perfect for running Hi steer system, all they would need is gears
$500
New Discs
New Calipers
New Pads,
and for the rear...
New Shoes
New Spring kit
New wheel cylinders
$500
