I'll check on monday but the only thing that changes your etest is if you put an engine that was not avalible from the manufacture for that vehicle. This only changes the limits and the type of test.
I talked to an MTO enforcement officer about tires sticking out past the body, He said that they can stick out as far as you want you only need mud flaps covering the bottom half of the rear tires.
