flat fenders and fast turn signals! how did you fix?
louie
like the title says i put on flat flat fenders and have put in bulbs but all i could find were 2 wire ones missing the third for parking lights.
for those that have done this what has been your remedy?
thanks
Well I'm still waiting for my LEDs. Too come in, but all I'm gunna do is wire in a normal bulb in Series and hide it somewhere. That will give me ennough resistance to have a normal flash.
New relay. Jeepforum has a bunch of threads. Although I think what Matt said will work. Also did you get the MetalCloaks? If so, which ones the overlines or the Arched?
Check my jeep build, project redpoint. Pull the flasher relay and scratch out one of the connections. Hardest part of the job was getting my hand up into the dash to remove the relay.
Also, my 4" LEDs are 3 wire (but you still have to do the fast flash mod). The LEDs are trucklite's
louie
neither had the 1500 set aside and noticed an add on used ottawa so checked it out. well safe to say this guy only wanted 350 and all i had to do was a bit of welding and grinding!
i am using incandescents right now. my problem is missing parking lights but mehh!
good idea brad will try tonight!!
