How to get jeep tj driver side rear axle to drop for coil installation?
K
Kyle TJ
Today while installing a 2" bb lift, I got the passenger side all back together, but the driver side won't drop enough to get the coil back in. Ive got only the sway bar disconnected. Did I need to do anything else?
Thanks
Mlorint
you need to disconnect the shocks to get them in. leave the sway bar attached. just undo the bottom bolt for the shocks with the frame supported and a jack under the axle, otherwise you could break your brake flex lines.
K
Kyle TJ
Alright, I already have the shocks disconnected as I was attempting to change them too. Damn bar pin bolts are all snapping off. I'll see what I can do tomorrow.
Thanks
That's not unusual. Actually I was surprised when I did mine that they didn't break but using an impact may have saved my bolts as it puts less stress than a breaker bar or ratchet. May want to look at a body lift. If the bolts break off you are looking at taking the nuts off as well and with a BL it gets easier. For me it was getting the driver side front. Afterwards I realized that I had left the front drive shaft attached and it was banging up against the skid. Duh
K
Kyle TJ
Got it in. Just had someone stand on the brake drum and used a spring compressor for help even though I don't think I should have needed it. Now I have to install my shocks and deal with more broken bolts. I'm almost thinking bar pin eliminators could be a good idea since its such a pain.
