HUB Question
justified
Any of you lads know if a TJ hub will fill on a YJ?. Both are D30's , and i can't really get a diffinitve answer on the net...
Reason i ask is the that a new aftermarket hub is over $100. If a TJ hub would fit it makes more sense to put my money into a used full front axle/carrier...If i went with a TJ front D30 , I would have the solid axle shaft to do the passenger side upgrade o get rid of the vacuum actuated 4x4x and a spare hub...
any in put appreciated. thx guys.
justified
Just a follow up for any future info seekers... The YJ hub is listed as only compatible with '87-'89...
