LF: Cheap Tires, 31's
JohnnyCrash
Hi, Looking for some cheap tires to throw on my jeep.
Preferably in the 31" range, even if they are worn, the stock 225's i have just
dont do the trick.
If anyone has any that they would like to unload for cheap it would be appreciated. My rims are 16's, but looking to pick up a set of 15's as well.
Also does anyone know what the largest tire that you can fit on a stock
96 ZJ is?
Thanks
W
whateverworks
I would first see if 15" rims will fit over your rotors and calipers before ya go and get them only to be disapointed that they will not work for you. Something tells me that the year you have will be fine but better safe than sorry when ya do find some 31" tires.
Kelly
JohnnyCrash
This is very true, Thanks for the heads up, im pretty sure they will fit, cause the 95 limited i have has 15" on it. :)
