LF: Oil pump for a 231
As luck would have it, as i was re-installing the two case sides after installing the SYE, my oil pump slid off, hit the ground and snapped one of the tabs along the edge :mad:
Anyone have one sitting around gathering dust or a parts 231 lying around....?
Jeepers this SYE kit has been a headache....
Thanks to all that can help :)
I have some tired old 242's you can check and if they have the same pump you are willing to dig through them
Dwayne
Thanks Dwayne. I will do some research tomorrow on this. They LOOK the same, however would like to try and confirm...
Could you PM me your number / location? It would have to be on Saturday morning as i am doing Daddy daycare a good chunk of the weekend....
Renfrew.
Should be around most of Saturday.
You would have to do the ripping apart of the t-case, or maybe there is one you can just have but it ran low on oil so you would still have to inspect it. I have a pretty good one in the truck but it will remain there until I have everything for my doubler in the next week or two.
H 613-433-7397
C 613-433-1857
Dwayne
From all accounts, the oil pump looks to be the same (Same part number at least). I'll give you a shout this evening!
Thanks,
Just updating this to close off. Was able to get a replacement part from Dwayne for my 231.
Thanks again...
