K
Kenny245
Read the mandatory items list and off to Princess Auto later today. Any suggestions for the hooks, Jack and Tow Strap?
Where can I get more info about the August 16 Carp Run, do I need to pre register with anyone or where is the meeting point and time?
a receiver for my trailer hitch with a big round ring on the end
I saw those at PA, and considered them. The only problem I had is from what I remember, they're too thick to take most winch hooks and shackles aren't they? Or do they have a smaller size?
If PA did not change the design they fit good on a standart winch hook. I had 2 of them on my FJ40, remember?I got one too, it probably is too big for standard winch hooks, but as for shackles you can get bigger ones.
AFAI remember he is driving '01 Dodge Ram. If the memory serves me good they have a good factory tow point in the front, but might be wrong. Kenny245 you better wait until we met for the run and then you will receive a a lot of priceless advices . Bring your own tow strap and in the worst case we will hook it up to the axle as we did for Jen's furst run.For location we need to know what truck you have?
do you really need a winch mount plate? Suggestion: come and see. than after you can start the mods.I saw a front mount receiver on ebay with a winch plate. Any suggestions?
yesFor the Carp run I guess I will bring a Tow Strap and and ring for the rear receiver, would this be OK?
I am planing on going but I have hit a snag, I am getting a d-ring that fits in my hidden hitch receiver but I can't get the hitch ball out. The pin appears to be stuck. PB Blaster, hitting it with a hammer and heating it didn't do anything. Any ideas? Should I still go? Also where do we meet and what time?
We ended up using a 3' pipe wrench and a vice getting mine out. Worst case scenario you get stuck, and I or someone else just pulls theirs out and use you it.
Just leave the draw bar in the hitch and remove the ball. Then we can hook a shackle to the draw bar with a strap. That is...IF you get stuck ;-)
So where are we supposed to meet and what time? Also how long does it usually take to do this trail?
