Z
zuk4life
Fits 1969-1995, Toyota 8" ring gear
"Powertrax" lockers will give you straight line performance that is equal to a solid spool yet it will automatically unlock to allow full differential effect in turns. "Powertrax" lockers also make less noise, reduce tire wear and driveline damage. You can replace your present spider gears with a "Powertrax" locker in your differential carrier without changing your ring and pinion settings and the entire job can be performed in your driveway with basic...
