Looking for set of rims - Tracker, Vitara - 15(16) X 7; 5X5.5 (139 MM)
As title says I am looking for set of rims - Tracker, Vitara, 15X7 or 16X7, 5X5.5 (139 mm) bolt pattern, prefer aluminum ones but nice steel/chrome ones will be good too.
Did I mention cheap? :)
So let me know what you have, thanks.
W
whateverworks
What year of Track/Kick or Vitara?
99 and up has a larger rotor and caliper and will not fit a 15" wheel
Kelly
F
fierodough
I have a set of steel rims 14" that WILL fit at 99+ because mine is a 99. ;) It's the offset you need to be concerned about on the 99+. If you get wheel spacers, you can run anything a Tracker / Sidekick or Samurai can run.
Steel rims are not pretty but you can sand and paint them or whatever. $50 for all 4..
Cheers!
F
fierodough
Oh! almost forgot! Get under your truck and check the front crossmember! If it's rusting out, you MAY still be covered under warranty! GM/suzuky has a "recall" on it for 10 yrs or 200,000 KM or something like that. Check out my video.
http://www.youtube.com/watch?v=jxZbm0afqvs
Cheers!
Z
zuk4life
1999-2004 tracker with a 4 bangger can run 15''wheels if it has the v6 it will have the big breaks. i have a nice set of aluminum wheels from a 2003 chevy tracker $150 613 9133901
zuk4life, I am interested and I will contact you soon; what exact size are they, can you e-mail me some pictures; thanks
Really. I've never seen a set of (decent) offroad tires in 14", maybe I've just never looked. Maybe they do exist. A quick Google of the tire size x14" doesn't yield much but a bunch of web wheelers. I should go check BFG or Interco's sites.
F
fierodough
You know what?.... I was wrong. :( they are 15" wheels. I have no idea why I thought they were 14" my bad.... I will get some pictures of them tonight. I'm running Kumho Road Venture MT, LT 215-75-R15 right now. I wanted to keep those rims to snadblast them and paint but I'm too lazy. :p
Still needed.
Actually looking for this particular ones:
They are coming from 2000 - 2004 Grand Vitara.
Let me know.
