So I screwed up my Panhard build today. Was all proud of myself for fish mouthing the end of the tube with a mini die grinder. Welded the end for the Johnny Joint on. Hmm, seems awfully long... Doh! Got a little carried away I guess.
I can cut the other end of the tube but will need to get the inside re-threaded for the TRE.
Can you recommend a machine shop that has taps on hand in the 1" or so range? Appears the thread is 1" - 14 TPI.
TIA
TIA
