http://www.mto.gov.on.ca/english/trucks/regulations/trailers.shtml
Just a page I found which means then if your rig and trailer exert less than 2800kg then you don't have to worry about stickers.
So even a Jeep like Scott's which will probably come in at close to 4000lbs (1815kg) with axles, tires and armor on a 2500lb (1135kg) trailer should be fine as there is 500lbs (227kg) tongue weight or 1200 lbs (545kg) allowed with equalizing hitches...
