Name that Fuel Pump
Ok guys, help me out here.
I have a mint cond fuel tank that I plan to use that I salvaged years ago from a car, no idea of the year, memeory tells me that it was an LTD or atleast that size of car. It mounted vertically at the front of the trunk/behind the back seat area.
Opened it up yesterday to inspect the sending unit and much to my suprise, it has a fuel pump in it. Now the question is will this pump flow enough for my 6.0 to run properly. If it will, it will be a big bonus as I...
K
kbrousseau
I think your memory serves you correctly. This is the listing that I have for 88 Ford LTD. Part # E2085H
90-100 psi 50gph
Buster
Ford Crown Vic, 5.0L MPFI, Early 90's is my guess.
Ah should have scrolled down and seen Keith's respons first!!
Sweet.
Now clarify for me, is that 90 - 100 psi and 50 gph suitable for the 6.0? My guess is yes
Those high PSI might come hard on your fuel pressure regulator.
Other than that its fine
BillaVista
PrettyBoy
It'll be fine. My LS2 pump (Bosch) is 72 psi and 53 gph.
What are you using for a regulator? I have one for sale - the one that came with the LS2
Also - what kind of fuel line / fittings are you planning on? I have a bunch left over too.
Hadn't given much thought to lines/fittings/regulator. I was just happy that I found a pump that would work.
If your extra stuff fits my budget, might as well buy it than souce elsewhere.
