Need toyota help
M
mudturtle
ive got a 87 toyota 4wd,,22r carb,,,thing starts great,,idols great,,u can rev the engine up fine,,it will idol all day,,u can drive around all day long at slow speed,,as soon as u hit 60,80 kms it die,s,,,its like theres no gas,,it will start right back up,,,,,,,,,,,ive checked the fuel filter,spark plugs,wires,,rotor and cap,,rebuilt carb,,tested the fuel pump,,,checked the fuel pump,,im lost and dont no what eles it could be,,ANY IDEAS WOULD BE AWSOME
W
whateverworks
Does it have a catylitic converter or resonator? Maybe they are plugged?
Kelly
How does it die? Losing power and sputtering, or like you turned off the key?
M
mudturtle
havent checked the coil yet,,in all my years with toys,,the coil uasally just quits working,,but it still mightb be,,,no cat,,straight pipe and muffler only,,,and it was sputtering untill rebuilt carb,,now its just like u turn the key off and then back on,,,,i was thinking it might be the fuel cut off seleniod,,
M
mudturtle
thanks for the help ppl,,i found out the problem,,the guy before me took a part of the backside of the carb and i didnt no it was gone,,found it fix it and working great now
