Power Steering into a Samurai!
8
89samurai
I'm new to the site, just had my 89' Samurai out for the first time last weekend. All went well except for the manual steering. The Sami has a 1.6L out of a tracker/sidekick in it and I'd like to covert it to power steering. From what I've read this is doable by using the Steering shaft, power steering pump and box from a 1990-1995 tracker/sidekick. (it also has a spring over axle lift in it)
-Is this all I will need?
-will I need anything else due to the lift?
-Would anyone have these from...
The bolt pattern is flipped on the boxes as far as I know (it's a 3 bolt triangle, and the end with the "point" is reversed between the two). You can either drill, sleeve and weld the new pattern, or a few places make swap brackets.
BTW, 1.8? Is that right? Or 1.6? I ask as I have no familiarity with the 1.8. [MENTION=2182]Garrett[/MENTION] might as I think Garth has a sport. I would have thought you could just use whatever PS pump is on there, and make some new lines if needed.
