This is about the point I stopped taking pictures because: 1. I couldnt post them and 2. I didnt have time, it was about a month to spring fever.
I bought a flip ring adapter for the dana 300 from novak.
0005Novak Adap by
Jeepage, on Flickr
Flipped the 300 upside down and installed it in the Jeep. I made a custom mount and reused the stock skidplate/crossmember on the YJ.
Next was wiring. I got a good set of diagrams for both my 93 XJ and the 89 YJ. Took the two harnesses and spliced them together. Took about 4 hours to get it running. Now if any of you have seen under the hood of my jeep you know it is a wiring nightmare. (Stay tuned later for a rewire).
Next I tore down my new front axle, an F250 HP D44. I ordered new 5.13 gears, a yukon grizzly full case locker and a set of Nitro Cromo shafts. With the help of Dwayne and his tools we set up the new gears and locker. Problem came when I wanted to convert my front to 5 lug to match the 9in rear but wanted to keep the F250 knuckles so I could do high steer. In order to get the brakes to clear the rims (15 inch) I had to use the F150 brakes. Needless to say you cant just bolt F150 brakes onto the F250 knuckle. In all my research everyone said it couldnt be done no matter the combination of parts. Well.... they are wrong, a little handy work with the plazma, some very percice notching and I got the half ton brakes on the 3/4 tonne knuckles. I wish I would have taken some pictures of this. If I ever tear the front end down I will post up some pictures.
I installed some new baljoints, reasembled everything and had it ready to be put in the truck.
