I am using the stock master with front Sami calipers on tthe rear. If you do not use a proportioning valve you will find that it is easy to lock the rear brakes when the weight transferes to the front during a stop. If this truck is regularly road driven I would reccomend getting the valve. I do not run a proportioning valve.
this is were I am got all the brakes converted to disk
installed the rear disk
removed stock valve at rear and installed adjusatable one
at front on right side there a spliter I guess it goes from the two flex hoses to the 4 steel I caped on one of the rear line and used the other to feed my rear
bleed brakes cant seem to get a hard pedal I don't see any leaks I am going to try and remove valve all together and see what happens
brakes worked fine before conversion?
any ides
