Sharp DT-100 - DLP projector $650.00 or best offer
F
FJ Matt
Sharp DT-100 - DLP projector $650.00 or best offer (Brand new sealed)
Manufacturer: Sharp Part Number:DT-100 General
Device Type DLP projector Width 12.4 in Depth 11.6 in Height 4.7 in Weight 8.6 lbs Projector / Panel
Image Brightness 1000 ANSI lumens Image Contrast Ratio 2500:1 Image Size 3.3 ft - 25 ft Resolution 854 x 480 Native Aspect Ratio Widescreen Video Bandwidth 108 MHz Max Sync Rate (V x H) 85 Hz x 70 KHz Lamp Type SHP 275 Watt Lamp Life Cycle 2000 hour(s) / 3000 hour(s) (economic...
Billygoat
Hey Matt,
So it's new? Wondering about the loudness of a fan or such. Do you have any experience with these units? Looking for something in the recroom, but we have alot of windows. That being said, it would probably be used most in the evening.
Interested. I'll chat with the finance minister.
The link is messed up I think...
F
FJ Matt
Hey Billygoat,
Yes it is new. The projector itself is pretty quiet on low mode, when you put it on high mode it will get louder, but not loud where you get annoyed. As well it all depends on where you have it mounted/sitting. try going to:
http://www.projectorcentral.com/sharp_dt100.htm
As for watching it durring the day, I wouldnt recommend that. Only use it at night. Don't get me wrong you will see the picture just fine and it will look gorgeous, but you don't want to use a projector for everyday watching. Use it for movies and your favorite T.V shows, and use you existing tv for everything else. Hope this helps.
Matt
Billygoat
Nope. Never been, but I've heard it's fun.
I was talking to the purse strings and she mentioned the tax bill is due, and about 4 other expenses. Looks like I'll pass on this. Good luck on the sale.
F
FJ Matt
Not a problem. I'm sure it will sell soon. Its too good of a deal to let go. I just need the cash for a lift. Tis the season!
