So..34's and a spring over??
I think there must be something in the air...
If I ever get one I'm going to use the same tire/wheel combo as on my XJ (16x8, 275/75-16 - ~32s). I figure it'll make it look more like a "sleeper".
Buster
I cannot tell a lie:), It belongs to a friend at work. I just have the job of making it run well. Needs a slight tune up, adjust the brakes and a general once over.:cool::beer:
BillaVista
PrettyBoy
Man, I'd rock that thing on the trails exactly how it is...well, after the Buster once-over, that is!!
Love those!!
Buster
Well, so far it doin pretty good. LR axle bolts were loose:confused: so I tightened them up and guess what?? Last one broke in the hub.:banghead::banghead:. A little drillin' and tapin' and out it came. Now the clutch pedal linkage has egged the holes so bad it almost worn completely thru. A little metal fab at work Monday should fix that though:D
Buster
I made need a hand for no particular reason!!! I let you know when I'll be out in the garage next. Lookin' after Connor at the moment!:banghead::beer:
