K
kbrousseau
Does anyone have any experience good, bad or otherwise with these tires?
The set I had last year had fairly soft sidewalls for the wheeling I was doing, I actually had to put a boot and tube in one because it was leaking air through a "bruise" I got. If you are not wheeling hard they are ok and also on a small truck they would probably be much better as the Cherokee probably is about 5000lbs and it is hard on sidewalls anyway.
Dwayne
