Toyota Parts
NRTYota
Picked up a bunch of parts this summer. Don't need most of them but got it as a package deal so if anyone is looking for anything on the list please let me know. Prices right now are reasonable offers
22RE Motor
Starters (3)
ECU
'83 Front and Rear Axle Set (Front one is apart and have a rebuild kit for it, Rear is still all together, pretty sure there a 3.70 gear set but will check)
Radiator (2)
Varies Drive Shafts
'90 Pickup Tailgate
Steering Columns
'86 IFS Front
NRTYota
They are 83' Pickup axles, how does $350 obo for the set and the front axle rebuild kit sound.
NRTYota
Update on the parts I have for sale. I'm looking at cleaning out the garage so all the parts I have for sale if not sold in a couple weeks I will be going through and scrap anything I don't want lying around any longer.
Drive Shaft $25
Rear End $50
Front Axle $150 w/ rebuild kit
$100 w/o rebuild kit
Rear Axle $100
(Needs to be rebuilt)
Leaf Spring $25
Steering Box $30
Steering Column $25
Transfer Case $100
22r Motor $200
Clutch $20
Master Clutch Cylinder $15
Brake Master & Booster $25
Air Box with Sensor $20
Ignition Coil $15
Fuel Sender Unit & Pump $20
Starter $20
Posted on Kijiji as well (With some pictures),
http://www.kijiji.ca/v-view-details.html?requestSource=b&adId=1100294429
badcompany
well:
starter
fuel pump
ign coil
air box and sensor
and maybe 2 driveshafts
ill take.
hear is the problem, your 4.5 hours away from me.
the next time ill be in the area is for spring fling 2016.
so if you do throw this stuff out keep my parts and in may ill get them.
thanks hear is my # in case you ever get to toronto before then
416 998 8982. thanks.
badcompany
So I'm getting out of the toyota game totally now so I will not need those parts anymore.
Thabks you.
I'll try to sell my drive train 1 last time but weather it sells or not it's comming out this spring after spring fling..
Thabks
Thabks you.
Thabks
Oh, and which way are you going now?
badcompany
sorry correction
in mid 2016 ill be putting in a 2001 5.3 just want to get one more e test in so
i have a full 2 years before i have to do it again if the truck lasts that long
trukie
Zooklounge Crawler
sorry correction
I've got a 5.3 with ECM and full harness I don't need anymore since I just got a LQ4... Just saying... :stir:
badcompany
thanks man. i have a 2001 5.3 already and a couple of months ago i had the computer and harness reworked to be stand alone.
im doing it little by little. the next step is an adapter from 4l60e to dana 300 if you have one of those.
trukie
Zooklounge Crawler
Sorry no adapter. I am going with a TH400 and haven't figured out what T-case I want to run.
I am in the same situation as you, I am still collecting parts.
