I've installed the Trailgear highsteer kit on my 85 xcab and now i'm at the pitman arm stage.I used the trail gear front spring hanger and a RUF (rears up front )pack to keep it low. my problem is the high steer kit came with a dropped pitman arm, the springs have little arch to them with the weight of the truck on them. After clearancing the rad support and rotating the steering box i have like 2.5" from the TRE to the spring sitting on flat ground with the weight on. i think i could get...
