trackick gears & locker in a Sami
Conestoga
Looking for trackick gears to install in my Sami. This will be a first for me so any advice/opinions are appreciated from those who have done it before. I'm currently running 33's with the stock 1.3L & t-case.
From the research I've done it looks like I'll need two sets of front gears from a trackick and a ring & pinion install kit. While I've got the diff's apart I was also thinking of going with a spool in the front, and limited slip for the rear.
Any thoughts? If anyone has any third...
Z
zuk4life
i have a few trackers fronts 462 grears 613 9133901 shane
Loco
I'd wheel it
I have a welded 5.13 tracker rear if you wanted to build yourself a hybrid (bigger ring gear) .
Bones
Active member
I have the set up tools and expiriance to do this install for you if you need difs biult.
5.13:1 gears from a 5 speed Kick would be better, but You will probably still need T case gears to comfortably run 33s. I have found that 31s with 5.13s is even a strech and would liked to add a 4:1 t case if I can find one cheap.
Breeze has the install kit avalible
