Mmmmmm.
So i called TSC they have tanks for Nitrogen but if i get my own, i have to buy the tank ($229) first then a fill ($40) and get a regulator (Which they do not have in stock at the moment).... I just need to confirm whether buddy's tank has a regulator and if so, i'll head over the to the one in Kemptville and fill up tonight.
regarding the regulator, I have this setup from ORI
http://www.undercoverfab.com/ori-struts/160-ori-dual-fill-charge-kit.html. What you are saying is that i will also need a regulator on top of the above?
Now, on to the actual ORI strut.
Currently, it is de-pressurized and they sit completely collapsed. I am assuming that once they are pressured up to 90psi, they will be fully extended is this correct?
What i am trying to do is get the ORI sitting at a state as it will sit once mounted on the jeep. That would be with the shaft extended about 6" to accommodate my 5" upward travel. Then i can set my locations for the upper mounts.
Am i off in my approach? Or do i mock something up based on fully compressed length + 6" and go with that?
