Dannyboy33
I was looking at my jeep a got to thinking how I could give it more ground clearance under the belly pan. My problem is that the Dodge TF727 tranny has a long arm for the mount.
So I was wondering if I made a ring that bolted on to the bolts that hold the transfer case is place would it be strong enough to take the torque as a tranny mount?? Then I could cut the factory tranny mount arm off. Now not to much moves around under the hood because I have AA motor mounts. If this would be strong...
