smallville
Was curious if anyone has put a diesel in a Zuki ? If so what best place to get the kit I just picked up a 1993 1.9TD. Any info would be great
i made my own plate and had my flywheel sent out. i found pdf's on the dimensions on yotatech. also i adapted my diesel to a toyota tranny. from all i read, 1.9's will grenade your sammi tranny. the kick tranny may be a better option but would be just as much fabrication to fit as it would be to go yota. and yota has better aftermarket support for tcase gears and doublers, not to mention a lower 1st gear ratio. diesel has it's pros and cons but with the aftermarket surrounding the VW TD's those cons can be pros depending how much money u throw at it.
my TD is stock and as long as it's in its spool range it'll perform like a stock 1.6 8valve but i find i can't shift fast enough on uphills to keep the turbo spooled on upshifts. otherwise, i have yet to stall it and love the extra torque. if you have any questions, don't hesitate to ask!
