'94 XJ with 3" Skyjacker and 31" tires.
jrhockey03
I'd like to get rid of my XJ. AX15 tranny, won't shift into 3 or 4. They are on the same shift rail so I'm guessing the pin/bolt that holds the fork onto the rail broke. The clutch is blown out of it but I do have another new one with the bearing. Has sway bar disconnects, power tower throttle body spacer, k&n filter and mopar roof mounted spare. It turns over but won't start. I think the fuel pump wires turned green because I can't hear the pump run when I turn it over. Nothing fancy for...
jrhockey03
I forgot the important stuff. Located near Franktown. Cell is 6138973355, ask for Jamie.
