98 tj 2.5l motor needed!!
W
woodendude
Hey all, I find myself needing a new, well running 2.5l for my TJ.lost the front cylinder and need it working ASAP...could also use someone to re&re it for me at a decent cost.
Could probably help you on the re-wire.. Been there so i have some memories :)
I have a 2.5 out of a 95 YJ. I think it would work if you changed all the electronics from yours over. 200 bucks and you get harness computer and all.
B
BigDaddy
I would consider Baja's engine as a viable option, he's asking a good price and I believe it has decent mileage as well but maybe he'll chime in to confirm. I just swapped a '94 YJ 2.5L into my '98 TJ and it was relatively easy. Here is a list of what needs to be swapped from your TJ's engine to the YJ's,
-Intake manifold (as a complete unit, with TB, fuel rail etc... good time to clean it)
-Both engine mount brackets
-Valve cover (if you feel the need, TJ's air box bolts to the valve cover, I left the YJ's cover on)
-*Coil
-*Cam shaft position sensor (thin plastic plate under the cap & rotor)
-*Oil pressure sending unit
-*Thermostat housing
-Power steeing pump bracket
That's all that I can recall, it may seem like a lot but it really isn't. The items marked with an * are there because their plugs are different.
If your Jeep is a manual, now would be a good time to change your clutch, for $200 it just makes sense.
The swap will take you the better part of a weekend. The only special tool you might need is a fuel line tool to remove the fuel line from the fuel rail. I used a couple picks and got it off.
Good luck in your quest...
Mitko
The G-Spot
-*Coil
X2. I can only add that this beats the price of any rebuild, with proper tools and organization will take between 6-8 hours (at least this longs it takes me). The line disconnect tool could be picked up at PA or CT (or borrowed from me); and in general it looks harder to swap the engine than actually is. If you have any Qs LMK.
W
woodendude
The things is I don't have the knowledge or skill set to rip into an engine and swap it out..Or i would be all over Baja's engine.. it is priced right and everything....Bigdaddy....How much would you want to spend a week end doing this for me? I will be generous!
W
woodendude
250k on that motor, mine just lost a cylinder at 230k would it really be a wise swap?
B
BigDaddy
I would have to get back to you on that. Do you have access to a heated garage by chance? ;)
What findings gave you the notion you lost a cylinder? Did you do a compression test on your engine to be certain of your findings?
W
woodendude
i do have access to a heated garage on Slack Rd until the end of the month....but I don't have the tools you would require... It is now at the garage and they did a compression test on friday and apperently zero compression..I asked that they do a leak down tomorrow to see if maybe just a valve.
W
woodendude
I do need to get it done soon, it's nearing time to put my bike away for the winter.... :)
bradleyfitz
My friend Alex got his replacement 2.5 from car-part.com a few years ago. IIRC it was ~$650 shipped from Calgary.
W
woodendude
Well the problem is solved..Thanks for the info Bradley, I may still need a motor in the near future!!
The cylinder walls were fine, must have dropped off on the exhaust stroke!!
