It is pretty easy, I am doing it right now actually following Albert's write up in Can4WD, I imagine googling it will pull up good results, it only works with certain compressors and I am using a Sanden Compressor which has a seperate crank case which I blocked off with a set screw and will fill with grease and then you need a check valve, blow off valve, regulator switch....hmmmmm.....it is a 3 page article so if you can't find it on the web just buy a copy of the magazine it is very informative.
Dwayne
