Cochise
Pretty sure it'll be whatever automotive grade is (45 degrees).
AN fittings are considered "exotic" compared to auto grade stuff. You'll have to buy a flare tool from a specialist shop for AN I'd suspect.
Ahh, ok. One less thing to worry about. The lines I bent and flared on the weekend for the rear axle went it and no leaks. I was worried that just pumping the pedal wasn't putting enough pressure to test the line/fitting connection (unlike a full bore at-speed panic stop) when I came across the above (OE vs. AN).
