Alright, this might get into a big discussion. I'll start with my own definitions, and do speak up if you disagree on these:
Tow strap: doesn't stretch, much like a chain, made to tow a vehicle on roads
Tug strap: does stretch a small amount, also called a recovery strap
John,
I agree tug straps, like any recovery equipment, must be used for what they were designed for. Taking a big run to pull someone out is always asking for trouble whatever the attachment material. But I don't see how these kinetic ropes are any different than tug straps which we've been using and recommending for years. Although they might stretch different amounts I don't see this mentioned anywhere. If you saw different information please share.
As for the winch, they usually come with steel wire which again if used improperly are just as dangerous as any strap, rope, or chain.
Mitko,
If you are recommending non stretching tow straps I'd like to hear your reasoning.
I, and I believe most club members past and present, have recommended tug straps because they stretch. For one, it will soften the impact on the tow points and the strap itself as the vehicles go over the big bumps during extraction. When a gentle tug doesn't work we back up a few feet and take a short run to gain momentum which will transfer into the strap (this is the kinetic part) and provide a stronger initial pull, and again the stretch makes this transfer of force gentler on the tow points.
Your turn :beer:
