Not a bad idea for a SWAG at total weight John, but I need quite bit more accurate than that (sprung and unsprung) for suspension tuning.
I already have corner sprung weights by multiplying spring deflection by spring rate at each corner (although they vary a little depending if I measure/multiply main rate, tender rate, or combined rate - which is a little odd becase in theory all springs in series resist the same force and coils don't have any friction between coils - but might just be tape-measure accuracy limitation?)
And I can take a pretty accurate SWAG at sprung weight because I know the weight of the brakes, wheels, tires, and can calc 1/2 the shock,axle, and link weight pretty easily.
I would just like to do some actual/accurate weighing for comparison - as results are a little less than expected.
(CSW = corner sprung weight)
Front Rear
CSW by primary 586.25 472.5
CSW by secondary 625.625 455
CSW by combined 608.3 462
CSW average 606.725 463.1666667
kids & gear (per corner) 100
us & gear (per corner) 200
Loaded CSW 806.725 563.1666667
End SW 1613.45 1126.333333
Axle 500 450
Suspension 50 70
Wheels 110 110
Tires 210 210
Brakes 60 60
End USW 930 900
End weight 2543.45 2026.333333
Weight 4569.783333
