I think it is a combination of tires too small for the amount of lift and possibly missing lug nuts. I think a nice set of 54" Boggers should solve the problem, just make sure all the lug nuts are on. :lmao::lmao::lmao:
I think you have the right setup, however you obviously sacrificed a little bit of lift for ride comfort. As long as you don't mind being one of the "small" guys on the trail!! A set of 31's would ideally match that little lift. As for steering I'd run an RC motor from Canadian Tire, might even consider rear steer!
