LF 38 tooth Speedo Gear for TJ (short shaft)
I am looking for a 38 tooth speedo gear for the TJ. My winter tires are still 31's and the speedo gear I have right now is for 33's. Let me know if anyone has one and how much. Tried the usual places and no luck. May have to go to the states.
Is this stock'ish? I do have my old Speedo that was replaced when i went to pulse....
bradleyfitz
Different axle gear ratio's came with different teeth counts for the speedo gear.
Chris, I have a 34 tooth one if you want it. It's probably close enough ... it's from running 3.73 and 30's. I would think it would be close enough to 4.10 and 31's...
Looking in the parts list it looks like the 4 cylinders which had 4.10 ratio if they were standard was running either a 39,40, or 41 depending on the tire size. Right now I have a 36 tooth which is ideal for 33's on 4.11 gearing as it is bang on. I think Tim's is probably closer to what I am looking for than 34 as the 34 is moving farther away. I have a stock one if you want it for 3.07s :)
bradleyfitz
Right you are.
No need, my speedo gear is electronic :)
