LF: Stock pitman arm... TJ / XJ, etc....
Dwayne... You happen to have a spare pitman arm kicking around? It seems that most of the jeeps in the '97-'05 date range have interchangeable pitman arms.. I would like to revert back to a stock setup to see if it would address the bump steer...
Anyone?
Yeah I have some and I think I might even have a few that I haven't drilled out lol. But mine will all be be pre '91 that is why I never mentioned anything I was not sure what crossed over but you are welcome to try one.
Dwayne
It's worth a shot..
I would still need to ream out the end to accomodate my 1T TRE's but i wonder if the splines on the other end are the same.....
You in town anytime soon :)
I will be up Dwayne's way this weelend most likely. I could swing in and grab it if that helps.
Dwayne, if it's still set up, no worries... I'll keep looking around. If it is off and Terry, you are around and could swing by that would be great...
Tim if you could verify that it is the actually same spline count on both I don't mind pulling one off.
dj
Hey Tim
I have one "virgin" pitman arm pulled. If this helps your issue and you don't want your drop pitman arm I would consider it as trade.
Dwayne
I can pick it up tomorrow, let me know.
Sent from my HTC Magic using Tapatalk
Sure Terry I am here most of the day Sunday and if not I will leave it outside the garage door.
Dwayne
10-4. Probably be someone late afternoon.
Sorry guys.... Fawkin' internet's been down here for most of the weekend.....
Dwayne, i can get a stock pitman arm from most shops for about $20.00 and change. This drop one is about $50+ if i recall from Claytons... PLUS, i had it reamed out for 1T TRE's...... So, don't know if it would work for you...
