When im looking for a Dana 44 from a jeep...say on www.car-part.com... What info do I put in??? Starting my search for cheap Dana 44's. I have a friend that has some old vehicles and axles lying around. But done know how to tell what the axles are.
if your planning on putting a D44 on the front of your truck I think your asking the wrong questions. firstly, carparts dot com isn't the place to start.
try here: http://www.coloradok5.com/axleguide.shtml
after identifying what a D44 looks like and what vehicles to find them under, go here: http://77cj.littlekeylime.com/web_rs44.html (don't forget the article about flat top knuckles)
but before you do all that reading, have you considered other axle swaps? not saying that a D44 is the wrong swap but it won't be easy to find one that matches your rear axle. (as far as I know the jeep rubi front D44 is the only one with the same bolt pattern) what I'm getting at is maybe you should do both axles. personally, I'd start looking for an old 77 78 bronco or 4x4 truck. hi pinion drivers drop D44, 9inch rear not to mention other goodies you may or may not want to use (D20 and/or NP205)
EB is ~1963 - 1977.
