MJ leafs
looking for a set of stock MJ (comanche) leaf springs. Not all sagged out though.
MJ leaves are hard to source.
If you want new at a reasonable price do a search at comancheclub.com. There is a vendor there that sells stock MJ leaves (both regular and metric tonne) for a reasonable amount. I forget how much they are but spidey-sense say something shy of $200 (for retail is a decent price)
K
kbrousseau
You could also try Malmberg's on Micheal street in Ottawa. They may be a bit more but they are local.
Ya all I really need is the main leaf so it may be worth my while to just get mallembergs to make them.
K
kbrousseau
If all you need is one leaf then Malmbergs is probably the easiest. They will need measurements for your old leaf. You will need to give them the thickness of the spring, the width, overall length and how far the hole for the center bolt is from either end (they arn't always in the center).
I have ordered many a spring from them over the years. :D
ok does anyone know these measurment. I dont have one to measure. These are going in my XJ.
I don't have the measurement but I do have an MJ. :)
How do they need to be measured? Installed? Along the outside main leaf? I can measure mine but I don't want to be blamed for incorrect measurements. You are welcome to swing by to take measurements if you want.
Search CC. There must be a thread on there with measurements somewhere.
Also a Pre-04 ford ranger or explorer spring will work too. Does anyone have any of those?
H
Hurricane
Si senor!
I'm stripping a '92 explorer right now. Wasn;t planning on keeping the rear leafs...they're yours if you want them
H
Hurricane
Near Winchester but I work in Kanata.
I may be heading out to Renfrew this weekend though to look at a truck though.
Still need to cut them out of the truck though
If you are heading this way and you get them out of the truck then I will take them. I could meet you in anywhere in Renfrew.
Pm me if you are coming and I will give you my number.
Scott
